| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): | 10.xx.xx.xxx |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Piping |
| Subarea: | Generic |
| Original Author: | Álvaro Melgarejo, Bentley Global Technical Support |
When the user wants to create an isometric view of a large pipeline, it might happen that the isometric view is not clear enough because of the size of the pipeline, and/or because there are too many elements in it. In this scenario the user has the possibility to split the pipeline into several parts, so for each part the pipeline is split into, an isometric view will be generated, thus increasing the clarity of the drawings.
