How to hardcode UOM of properties in Advanced Query EDM-CE
Product(s):OpenPlant PlantSight
Version(s):
CONNECT Edition 10.11.++
Environment: Windows 10/11 (64-bit)
Area: Query
Subarea: Advanced Query
Original Author:Fer Mykiel Gonzales, Bentley Technical Support Group
When doing a query, uom can be missing in the properties. In this wiki article, it will explain two approaches on to add uom to define the properties.
1. Go to PlantSight and Open the iModel
2. Open Query Browser in Tag Management
3. Define a Query and set to turn on Advanced Mode
4. Add the following in your query (example used is for Equipment Height):
5. Run or Save Query
Results:
