Applies To | |
Product(s): | Bentley Class Editor |
Version(s): | CONNECT Edition (10.11.00.260) |
Environment: | Windows 10/11 (64 bit) |
Area: | Schema Editor |
Subarea: | EC Expression |
Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
As the per the requirement user wants to write an EC Expression in the conditional form. For Example The ECExpression has an IIF statement and when this is the case, both possible expressions need to be considered in the Parser Regular Expression. The two cases here are, with and without a valid Insulation value.
Example:
Insulation defined as NA: A50-100-SERV-222-CS150
Insulation defined as INS (Or any other value): A50-100-SERV-222-CS150-INS
Tag parts defined as:
Plant Area – A50
Nominal Diameter – 100
Service - SERV
Number – 222
Specification – CS150
Insulation - INS
The BAR symbol shown above, is required to split the two possible results to be evaluated.
Note: Consider the Nominal Diameter is metric unit.The Parser Regular Expression is read and if either side of the bar evaluates to TRUE, then it will process the tag and publish this to PlantSight.
NOTE: If the units for the project are in imperial, then this will need to be adjusted further. Also note, if any of the other properties used in the expression contain spaces or dashes in the value, the parser regular expression will need to be adjusted further. The adjustments required would be for the inch marks, fraction slashes, spaces, and dashes. Dashes especially because o the tag format contains dashes.
This tool Rad Regex Designer is very valuable when creating parsers and checking them for correctness.
It is free and can be found here: https://rad-software-regular-expression-designer.software.informer.com/
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
