OpenPlant Project Administrator CONNECT Edition allows users to automate the simple configuration and project setup tasks thereby ensuring that the user is not needlessly exposed to a developer’s tool for schema management when making simple changes that are done at the beginning of every project. It has common tools for all OpenPlant applications including Specification Generator and Reports Editor. Class Editor will still be shipped allowing users to do more complex tasks. For information on system requirements, licensing, and what's new in this release, see the ReadMe document.
LICENSE USE
CONNECT Licensing: This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
SUPPORTED OPERATING SYSTEMS - Windows 10 (64-bit), Windows 8.1 (64-bit), Windows 7 (64 bit)
You can find these builds on Software Downloads:
TECHTALK - New
Visit Bentley Plant Official YouTube Channel - Click below button
Like Subscribe Share
FIRESIDE CHAT- New
From Mouth of Product Management - Click Here >>>
Check Video Content - Bentley LEARN Server
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
