| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): | 10.xx.xx.xxx |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Properties |
| Subarea: | |
| Original Author: | Álvaro Melgarejo, Bentley Global Technical Support |
To modify the displayed value of a property by means of an ECExpression.
Problem Description
The class Tap Connection has a property called Branch Code. The user wants to modify the value of that property so it displays the nominal diameter of both pipes connected by the tap connection in this fashion: DN<Diameter_1>/DN<Diameter_2>.
Below is a step-by-step of how to achieve this. A tap connection between a 250 mm diameter pipe and a 50 mm diameter pipe is used as an example. The Branch Code property may display nothing or something different than desired at this point.
Steps to Resolve
