| Version(s): |
CONNECT Edition 10.11.++ |
| Environment: | Windows 10/11 (64-bit) |
| Area: | Reports |
| Subarea: | |
| Original Author: | Fer Mykiel Gonzales, Bentley Global Technical Support |
To create a report that contains Microstation-based Property such as Element ID, this wiki explains the options to implement this. There are 2 ways that user can create a report, either through Details dialog or Microstation's Report tool.
A. Details Dialog
B. Microstation Report
Note: To re-use the created report, use import and select the DGN where the report was originally created.
