| Version(s): | CONNECT Edition (10.11.00.260) |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Custom Component |
| Subarea: | Component Type |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
In Open Plant Modeler sometimes user want to create a custom component under piping and doesn't find correct component type in the list. In this example user doesn't find Flow Element.
In this article shows how to add the component type.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
