List of basic Supported Syntax that needed to Construct a Query in PlantSight-CE
Product(s):Engineering Data Manager
Version(s):
Environment:Windows 10/11 (64 bit)
Area:PlantSight
Subarea:EDM
Original Author: Sameer Bagwan, Bentley Global Technical Support
Below is a list of the different MySQL statements that can be used inside of a query. This is a list of the minimum, basic statements needed to construct a query. This is NOT ALL possible query statements.
Note : This is NOT ALL possible query statements, but few of them.
Still a Problem?
Comments or Corrections?
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
