| Product(s): | OpenPlant CONNECT Edition |
| Version(s): | |
| Environment: | Windows 11 (64 bit) |
| Area: | Uninstall/Repair/Modify |
| Subarea: | - |
| Original Author: | Sameer Bagwan, Bentley Global Technical Support |
This document explains the procedure to Modify/Uninstall/Repair OpenPlant Products
Modify/Uninstall:
Repairing the Application:
To access the repair option directly from the installer files for OpenPlant CONNECT, follow these steps:
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
