Display Pipe Bend Coordinates in OpenPlant Isometrics Manager-CE
Product(s):OpenPlant Isometrics Manager CONNECT Edition
Version(s):10.XX.XX.XXX
Area: Properties
Subarea: Pipe Bend - Coordinates
Original Author:Evander Cabalagan, Bentley Global Technical Support
Normally, pipe bend coordinates are not included in generated isometrics. Moreover, there are cases where coordinates must be visible. This can be achieved by modifying the isometrics configuration.
  1. Launch piping model in OpenPlant Modeler.
  2. Generate the isometrics.
  3. In isometrics configuration under User Label, create a new label and add the following values.
    Name: Bend Radius and Bend Labels
    Include: IE_TYPE=CT_BEND
    Text: R=$(BRADIUS:#.#)$$(BANGLE:#.#)°$$(COORD)
    TYPE: NOTE
    CELL NAME: NOTE
  4. Save the changes.
  5. Generate the isometrics to verify the result.
Still A Problem?
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../modifying-the-isometric-content
Comments or Corrections?
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
