| Product(s): | OpenPlant CONNECT Edition |
| Version(s): | CONNECT Edition 10.11.++ |
| Environment: | Windows 10/11 (64-bit) |
| Area: | Schema Customization |
| Subarea: | User Interface |
| Original Author: | Joseph Gelacio, Bentley Product Advantage Group |
This wiki will show how to remove the jumper symbol in the Piepline.
Launch Class Editor and load OpenPlant_PID.01.08.ecschema.xml schema.
Supplement it with OpenPlant_PID_Supplemental_Design.01.08.ecschema.xml schema.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
