| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.10.01.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
In AutoPLANT Modeler, most of the companies use their standard template for generating Isometric. OPIM uses default seed file (isoseed.dgn) as template for generating isometric. Any file with extension excluding .DGN will not be supported.
C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config
communities.bentley.com/.../12636.setting-file-type-dgn-or-dwg-and-paper-setting
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
