To Resolve Unable to place symbol: SWEBW_MT in OPIM -CE
Product(s):OpenPlant Isometrics Manager CONNECT Edition
Version(s):
10.XX.XX.XX
Area: Error, Logs, Messages, Crashes
Subarea:
Original Author:Fer Mykiel Gonzales,Bentley Technical Support Group
Problem Description:
When generating an isometrics that contains a Swaged Eccentric Pipe Nipple, the following error message appears:
This is after creating a custom cell (derived from the OOTB SWEPE_MT) for the aforementioned class.
1.Open the cell file that contains the created SWEBW_MT. If you don't have one, kindly import the file from  communities.bentley.com/.../lisocomp.cel and add the model in custom.cel.
2. Open the SWEBW_MT for editing.
3. Measure the Connection Point 1 (CP1) to Intersection Point (IP). Take note.
4. Repeat step 3 for CP2 and IP.
5. Open the symbolsizes.def from the Isometric Style folder.
6. Search for the ECC
7. Copy the first 2 lines under the eccentric section and paste it at the last entry of the same section.
8. Rename the DEF line to your preference. In this example, ECC_11_2.
9. Modify the SEGLEN line to match the measurement done in steps 3 and 4. In this example, CP1-IP is measured to be 2mm and CP2-IP is measured to be 11mm.
10. Save the modified symbolsizes.def.
11. Launch Bentley Class Editor.
12. Open the OpenPlant_3D.01.08 schema. Supplement it with OpenPlant_3D_Supplemental_Isometrics_Isoextractor.01.08.ecschema.
13. Go to the ECCENTRIC_SWAGED_PIPE_NIPPLE Class.
14. Under the Isometric Component Attribute, modify the Scaler to match was added in step 9.
Result:
Isometric can be generated successfully with the custom cell added for the ECCENTRIC SWAGED PIPE NIPPLE with a Butt Weld and Male Thread End Preparations.
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Technical Support group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround
