Applies To | |
Product(s): | OpenPlant Project Administrator Connect Edition |
Version(s): | CONNECT Edition Update 11 (10.11.00.180) |
Environment: | Windows 10 (64 bit) |
Area: | Schemas |
Subarea: | Setup |
Original Author: | Analyst Name, Bentley Global Technical Support Group |
In OpenPlant Project Administrator, setup customize schema to PlantSight , iTwin Setup Fails and display error as to "Setting up Schemas.....Failed"
While working in OpenPlant Project Administrator, a user has established a new PlantSight project and attempted to push the schema to iTwin. However, after associating the PlantSight project with a specific workset, the setup fails during the schema setup, displaying an error with minimal information. No specific details could be obtained from the log file.
Here are the steps to rectify such an error. These steps are applicable to the specific scenario when the setup fails while pushing the schema to iTwin.
Note-If it fails due to another issue, consider creating a new iTwin model and performing the setup.
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
