| Product(s): | OpenPlant |
| Version(s): | CONNECT Edition Update 11 (10.xx.xx.xxx) |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Schemas |
| Subarea: | Embedded Schemas |
| Original Author: | Joseph Gelacio, Bentley Global Technical Support Group |
In OpenPlant, sometimes schemas are embedded and cannot be deleted by the key in ecx schema delete
In OpenPlant Modeler, the embedded schemas cannot be deleted by the key in ecx schema delete and is showing the error "already being referenced by other ECShema"
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
