When we carry out a major upgrade to a BCDE server, we often replace some of the files associated with the interface, such as those containing code responsible for generating the menus you use to Issue a document or change its metadata, with newer, better versions.
Unfortunately, if the files that we're replacing have been cached by your browser, you won't automatically get the newer versions of these from the BCDE server because your browser won't check if there are any. This can result in bits of the BCDE website not looking right, or even not working at all.
In order to fix this, you need to clear out your browser's cache by deleting the temporary internet files it has stored on your computer. Each browser stores these files in a different place, so the method for clearing them is different for each one.
Steps on how to clear each browser's cache is listed below.
Product(s):
BCDE
Version(s):
7.3 and above
Area:
Miscellaneous
Original Author:
Date Logged & Current Version
02/17/2022
Simply press and hold CTRL and SHIFT then press the Delete key (in any Browser), and then follow the final screenshot setup from each heading below. (Keeping an eye to set the time frame to Everything/all time)
Google Chrome:
- CTRL and SHIFT then Delete keys (to skip steps 2 to 4) OR put chrome://settings/clearBrowserData in your URL bar to get there directly.
- Click on the 3 dots at the top right of the browser
- Hover over 'History' and then click on 'History' in the sub-menu.
- At the top left click 'Clear browsing data'.
- On the 'Advanced' tab, ensure the 'Time range' is set to 'All time'.
- Tick only the 'Cached images and files' box and click 'Clear data'.
(One this has completed you'll be taken to Chrome's Settings page.)
Firefox:
- CTRL and SHIFT then Delete keys (to skip step 2)
- Click on the 'History' drop-down menu (click 'alt' key if you can't see it) and click 'Clear Recent History...'
- Make sure the 'Time range to clear' option is set to 'Everything''
- Tick only the 'Cache' box and click 'Clear Now'.
Microsoft Edge:
- CTRL and SHIFT then Delete keys (to skip steps 2 & 3) OR put edge://settings/clearBrowserData in your URL bar to get there directly.
- At the top right of the browser, click on the horizontal 3 dots and then click 'History'.
- Then click on the 3 dots in the new menu, then 'Clear browsing'
- Set time range to All time and tick as below
- Tick only the 'Cached images and files' box and click 'Clear'
Safari:
- Ensure you have the 'Developer' drop-down menu showing - click the Safari drop-down menu and click Preferences
- Go to the Advanced tab and ensure the 'Show Develop menu in menu bar' box is ticked.
- When the 'Developer' drop-down menu is showing, click 'Developer' and click on 'Empty Caches'.
Internet Explorer (IE11):
- Either click on the Tools drop-down menu (click 'alt' key if you can't see it) at the top left of the browser or click the cog icon at the top right
3. Choose 'Internet Options'.
4. On the 'General' tab, under the 'Browsing History' heading, click 'Delete'.
5. Tick only the 'Temporary Internet files and website files' box and click 'Delete'.
(Internet Explorer will display a confirmation banner, at the bottom of the browser, once this has finished.)
If you have any problems at all, contact your project administrator or BCDE Support
