| Version(s): | CONNECT Edition Update 11 (10.xx.xx.xxx) |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Settings |
| Subarea: | - |
| Original Author: | Joseph Gelacio, Bentley Global Technical Support Group |
The following procedure details how to apply Display Rule to OpenPlant classes by Common Properties.
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
