| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): | 10.xx.xx.xxx |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Schemas |
| Subarea: | Supplemental schemas - Custom Attributes |
| Original Author: | Álvaro Melgarejo, Bentley Global Technical Support |
This wiki assumes basic understanding of the Bentley Class Editor and the XML schemas used by OpenPlant Modeler.
When adding a Calculated ECProperty Specification custom attribute to a property of the SUPPORT class with Bentley Class Editor, the user needs to make sure that such custom attribute is located in the OpenPlant_3D_Supplemental_Modeling schema. Otherwise, unexpected crashes might happen while using OpenPlant Modeler.
Problem Description
OpenPlant Modeler crashes consistently when copying a pipe with supports of the class SUPPORT on it, given that any of the SUPPORT class properties have a Calculated ECProperty Specification custom attribute located in the OpenPlant_3D schema and its ECExpression fetches data from the pipe run.
Steps to Resolve
