In this document, we can compare the creation of multiple Named Versions and evaluate them using the viewer in PlantSight.
| Product(s): | PlantSight |
| Version(s): | PS3 |
| Environment: | Windows 11 (64 bit) |
| Area: | Named Version |
| Subarea: | Viewer |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support Group |
When a user uploads 3D model data to PlantSight, subsequent modifications and updates may occur. To safeguard against data corruption, PlantSight offers a ‘Named Version’ functionality. By creating named versions at each milestone, users can recover older data and compare it with the updated version.
Create a First Named Version when pushing data for the first time, achieving a 30% milestone. Follow these steps:
For subsequent data pushes at the 60% milestone, create another Named Version using the same steps as above.
In the Named Version section of Data Manager, you’ll find the two latest created Named Versions (at 30% and 60% milestones).
Note: Only 3D Model data compare with this version compare option in the viewer section of PlantSight
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
