| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.11.01.136 |
| Environment: | Windows 11 (64-bit) |
| Area: | Isometrics |
| Subarea: | Labels |
| Original Author: | Fer Mykiel Gonzales, Bentley Global Technical Support |
For isometrics having continuation label, the label shows as "0:" which is inconsistent to what is set in the Style Configuration. By default, the connection label should display as "Cont. to:
The Continuation Label shows inconsistency with what is set in the Style Configuration. This is true when using Isometric Break Point or Manually assigning piping components to isos through Pipeline Manager.
Below steps is the workaround for this issue.
Note: There are instances that user may encounter the issue when generating the isometric:
y
If so, kindly follow the steps mentioned in To Troubleshoot Error Message "Unable to cast object of type 'System.DBNull' to type''System.String'." Error. - OpenPlant | AutoPLANT Wiki - OpenPlant | AutoPLANT - Bentley Communities
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
