Applies To | |
Product(s): | OpenPlant Isometrics Manager |
Version(s): | CONNECT Edition Update 11 (10.XX.XX.XXX) |
Environment: | Windows 10 (64 bit) |
Area: | Settings/Attributes |
Subarea: | - |
Original Author: | Evander Cabalagan, Bentley Global Technical Support Group |
The bolt label in generated isometrics is missing due to the error message appearing in isometrics configuration box.
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
