| Product(s): | Exor TMA Manager | ||
| Version(s): | N/A | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
User query – “Just sent an FPN in error, is there any way I can revoke it or cancel it using Atlas?”
To revoke an FPN you can issue a 2101 FPN Withdrawal notice, which effectively cancels the FPN.
You should be able to send this notice via the TMA1100 FPN’s form by querying the FPN, click the Send Notice button to open the Noticing Assistant, then select the 2101 FPN Withdrawal notice and issue it.
