| Product(s): | Exor Network Manager | ||
| Version(s): | 4.7.0.0 | ||
| Area: | Locator | ||
| Subarea: | |||
When trying to use either the measure tool, i.e. measure area/length, the following error message appears:
Your query failed. Please enter the line again
Within the java console, the code creates a select query. After running this query in SQL Plus, an error message appears indicating that an identifier is invalid. This usually means that the version of the mapviewer package is incorrect.
Ensure you have the latest mapviewer package or contact TSG support to determine the correct version for your system.
