| | Product(s): | Exor Network Manager | |
| | Version(s): | 04.05.00.23 | |
| | Environment: | N\A | |
| | Area: | Other | |
| | Subarea: | N\A | |
We refreshed our Test Environment with a copy of Production. However there are some triggers that are missing / different. Those are mostly v_nm_xx_nw_i_trg triggers (the xx part is the asset type code).
You need to go to Asset Metamodel form on the newly refreshed test system and re-create the v_nm_xx_nw_i_trg triggers (the xx part is the asset type code) by hitting the ‘create view’ button for the corresponding asset types. Triggers will be created alongside with views.
