| Product(s): | Exor TMA Noticing Manager | ||
| Version(s): | 04.07.00.13 | ||
| Area: | Notices | ||
| Subarea: | N\A |
When sending notice, sender receiving warning message in TMA1001:
Error Correction notice is not amending any details
This is usually caused when sending wrong notice. For example:
1. Sender wants to change works start date;
2. Sender picks Works Data Variation notice, change date, sends
*Warning message above shows up*
3. Receiver can't see changed works start date
Sender should choose Modified Application (0311) notice to make such changes and send to user.
| Original Author: | Edvinas Perminas |
