Product(s): |
Exor Enquiry Manager |
Version(s): |
04.05.00.00 |
Environment: |
N\A |
Area: |
Public Enquiries |
Subarea: |
N\A |
Error
On opening PEM (DOC0150) form the error below appears.
FRM-40735: WHEN-NEW-FORM-INSTANCE trigger raised unhandled exception ORA-06502
Explanation
This happens because Admin Unit is not specified for the user.
How to Avoid
Connect as Highways user
In Users form (HIG1832) select the user.
- and set value for Admin Unit field.
