| Product(s): | Exor Maintenance Manager | ||
| Version(s): | 4500 | ||
| Area: | Inspection Loader | ||
| Subarea: | N/A |
A user receives the following error whilst trying to load files using the Inspection Loader (Part 2):
oracle error: ora-00942: table or view does not exist
occured in: dl_lo_2
The user does not have the correct setup to allow for files to be loaded using the Inspection Loader. Please contact support and ask for the script hhtabv3.sql to resolve the issue.
| Original Author: | Fezan Khan |
