Discoverer return not all records
Product(s):Discoverer reports
Version(s):4.x
Environment:N/A
Area:Reports
Subarea:N/A
Issue
The report for section membership within the Discoverer report is not picking up all of the section that have been created in Spatial Manager.
It can be that there is a record limit specified on Discoverer what is causing the issue. Open Discoverer, then go to Preferences and untick ‘Limit retrieved query data to’ or set it to 999999, press on Apply to save changes. Close Discoverer and try to run the report again.
