| | Product(s): | Exor Network Manager | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | Directories | |
| | Subarea: | Permissions | |
Oracle Directory Java Permissions
When experiencing problems with files in Oracle Directories you may be asked to refresh the Java Permissions for a directory.
To do this:
- Open the HIG1895 exor>Directory Management>Directories form
- Select the directory you need to refresh permissions for
- Make a note of all roles and modes shown on the Roles tab for that directory, then delete each role using the delete button on the toolbar.
- Save the changes.
- Add each role back to the directory using the same mode as before
- Save the changes. You should see a tick in the applied box
- Select the Java Role Privs tab and click All Off for each role
- Save the changes.
- Click the All On button for each role.
- Save the changes.
NOTE: You may need to log out of the application and close all internet browser windows before the changes have an effect.
| | Original Author: | Lee Jackson | |
