| Product(s): | Exor Network Manager | ||
| Version(s): | 04.05.00.00 | ||
| Area: | Other | ||
| Subarea: | N/A |
Whenever you try to download a file from a specific directory you receiving this error message below in your browser:
The database path must be accessible by UTL FILE DIR parameter on the database itself. You can select this value by running following script
If necessary add missing privileges or update UTL FILE DIR parameter.
How to change UTL FILE DIR parameter: If your Database initialization parameters are stored in SPFILE (user can check this by running following script)
| Original Author: | Edvinas Perminas |
