| Product(s): | Exor Maintenance Manager | ||
| Version(s): | 4.3.0.0 | ||
| Area: | Interface | ||
| Subarea: | N/A |
Invalid location or invalid file error when running the interface extracts or imports.
There are 2 settings which are normally either not set or set incorrectly to a path that doesn't exist:
It either needs to be set to '*' which allows any location on the database server to be used, or to the specific path used in the interpath user option. You will need to ask your database administrator to change this for you as it requires a restart of the database.
