| Product(s): | Exor Maintenance Manager | ||
| Version(s): | 4.8.0.0 | ||
| Area: | Inventory Loader | ||
| Subarea: | N/A |
Stage 2 of the inventory loader fails with error ORA-00904: "ITY"."ITY_HHPOS120": invalid identifier even though it's worked successfully before. Often happens after an upgrade has been applied.
Run the latest version of the script exor\mai\admin\views\mai_transviews.sql. The right version for 4.8.0.0 is 2.7.
| Original Author: | Sarah Willis-Culpitt |
