Product(s): | Assetwise ALIM Linear Referencing Services | ||
Version(s): | 1.3.19.1 | ||
Environment: | N/A | ||
Area: | Asset Maintenance | ||
Subarea: | How To: Mass End-date or Delete Assets |
How to bulk end-date or delete assets in AWLRS
Open the Asset Maintenance Form in AWLRS and select Asset Criteria
Select Open Asset Query
Enter a name for the Query. If you select [Temporary], the query will only be useable during the current session. Select an asset type and attributes to query the assets to end-date or delete and press either
[Save Changes] or [Save Changes and Close].
Press the [Search] Button to execute the query and return results. Select the assets to end-date or delete and then press the [Show only selected X assets] where X represents the number of assets selected. This will open a tool menu that will allow the user to either bulk end-date or delete the chosen assets. NOTE: You can also access the Global Asset Update tool from this menu.
Original Author: | Jon Libby |
