| Product(s): | Assetwise Linear Network Management | ||
| Version(s): | ALL | ||
| Area: | Center Map | ||
| Subarea: | Coordinate display length |
Problem: Default number of decimal places is limited to 4 decimal places
Resolution: The config.json file (usually located at: \\inetpub\wwwroot\AWLRS_BC\app\config\config.json will need to be edited. Look for the following lines in the file. You can modify the decimal format and places here. Increasing the "decimalPlaces" value will allow the user to enter an entire coordinate when prompted in the Center Map to enter the X and Y coordinates to zoom to and if selected, drop a pin marker on the map.
| Original Author: | Jon Libby |
