| Product(s): | Assetwise Linear Network Management | ||
| Version(s): | ALL | ||
| Area: | Password Policy | ||
| Subarea: | N/A |
The following changes will remove the @ symbol from the AWLRS Local Password Policy and Email Criteria found in Section 7 of the AWLRS Product Installation and Upgrade Guide v1.3. Inclusion of the @ symbol in your password is a known issue. It will prevent the AWLRS Map from displaying properly.
File to change: config.json
File Location: [AWLRS UI application deployment path]\app\config\config.json
Lines 241 and 242 need to be updated to the following:
"regExp": "^(?=.*[a-z])(?=.*[A-Z])(?=.*[0-9])(?=.*[!#\\$%\\^&\\*])(?=.{8,})",
"passwordHint": "Min Length 8 at least one from each a-z, A-Z, 0-9, !#\\$%\\^&\\*",
Final step is to execute iisreset on the IIS Server to force the updates to the password policy checks.
| Original Author: | Jon Libby |
