| | Product(s): | AssetWise ALIM for Transportation | |
| | Version(s): | 01.03.15.01 | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
Sometimes in ALIM for Transportation, dates can appear in a format that doesn't match your Windows language / region settings, e.g. dates appear in US format when your computer is set to UK format.
- Click the 3 dots on the top right of your browser window, then select 'Languages' from the list on the left hand side.
- Check which languages are listed. Use the Add Languages button if the right one is not displayed.
- If you want dates to display in UK format, make sure you have 'English (United Kingdom)' selected, not just 'English'.
- Click the 3 dots against the language you want to use and select 'Display Google Chrome in this language' in Chrome, or 'Display Microsoft Edge in this language' from the menu.
- Restart the browser for the changes to be applied, then log into the application again.
