| Product(s): | Exor Forms | ||
| Version(s): | n/a | ||
| Area: | N/A | ||
| Subarea: | N/A |
When trying to start up Exor, a certificate error appears:
Failed to validate certificate. The application will not be executed.
This usually happens because of a problem with the signing authority and is often resolved after a few minutes so no action needs to be taken. If it goes on for longer though, a workaround is:
