About SAP HANA
SAP HANA is an in-memory, column-oriented, relational database management system developed and marketed by SAP SE. Its primary function as a database server is to store and retrieve data as requested by the applications. In addition, it performs advanced analytics (predictive analytics, spatial data processing, text analytics, text search, streaming analytics, graph data processing) and includes extract, transform, load (ETL) capabilities as well as an application server.
BECS SAP HANA Connector enables very easy and quick integration between SAP HANA and 3rd party systems. BECS SAP HANA Connector has implemented following set of functions:
SAP HANA Tabble or View, SAP HANA SQL Command Executor, SAP HANA Stored Procedures.
SAP Certificates
BECS has been repeatedly fully certified by SAP for both existing SAP certification levels: SAP NetWeaver 7.50 and SAP HANA 2.0 SP021. Currently, after changing the SAP policy the certification is not possible.
How to use BECS SAP HANA Connector
This short video shows how to use BECS SAP HANA connector.
How it works
The next videos show how to work with BECS SAP HANA connector:
BECS SAP HANA Connector documentation
How to install BECS SAP HANA Connector
BECS SAP HANA Connector prerequisites
BECS SAP HANA Connector requires:
BECS SAP HANA Connector Installation Procedure
Whole process will drive following steps:
BECS_5F00_SAP_5F00_HANA_5F00_Connector_5F00_DLLs.zip
