BECS Documentum Connector
About Documentum
Documentum is an enterprise content management platform, now owned by OpenText. It provides management capabilities for all types of content. The core of Documentum is a repository in which the content is stored securely under compliance rules and a unified environment. Documentum provides services such as document management, collaboration, search, content classification, input management, Business Process Management (BPM), customer communication management and Web content management.
BECS Documentum Connector enables very easy and quick integration between Documentum and 3rd party systems. BECS Documentum Connector has implemented following set of functions:
Check Out Document, Check In Document, Full Context Search, Get Reims Document Metadata, Get Reims Document, Update Reims Doc Metadata Object, Push Doc With Metadata In Reims.
How it works
BECS Documentum Connector Documentation
How to install BECS Documentum Connector
BECS Documentum Connector Prerequisites
BECS Documentum Connector requires:
BECS Documentum Connector Installation Procedure
Whole process will drive following steps:
  1. Installation of standard BECS package
  2. After installation (if standard package does not include Documentum Connector), it is necessary copy dll files ”Ace.Integrator.dll, Ace.Integrator.DocumentumReims.dll, Ace.Integrator.DocumentumReims.dll.config, Ace.Integrator.DocumentumReims.pdb” to BECS installation path.
  3. After installation (if standard package does not include Maximo Connector), it is necessary copy dll files ”Ace.Integrator.dll, Ace.Integrator.DocumentumReims.dll, Ace.Integrator.DocumentumReims.dll.config, Ace.Integrator.DocumentumReims.pdb” to BECS Visual Architect installation path (Architect\Extensions\Application).
  4. Product will be after Activation ready to use.
BECS Documentum Connector Downloads
Documentum-Reims-Connector-DLLs.zip
