About ESRI
ESRI (Environmental Systems Research Institute) is an international supplier of geographic information system (GIS) software, web GIS and geodatabase management applications. ESRI uses the name ArcGIS to refer to its suite of GIS software products, which operate on desktop, server, and mobile platforms. ArcGIS also includes developer products and web services. In a general sense, the term GIS describes any information system that integrates, stores, edits, analyzes, shares and displays geographic information for informing decision making.
BECS ESRI Connector enables very easy and quick integration between ESRI and 3rd party systems. BECS ESRI Connector has implemented following set of functions:
Create Attribute for Feature, Create Feature in Layer, Create Polygon in ESRI Layer, Create Marker in ESRI Layer, Read content of ESRI Layers, Read ESRI Layers, Update Polygon in ESRI Layer, Delete Polygon in ESRI Layer.
How it works
The next videos show how to work with BECS ESRI connector:
How to install BECS ESRI Connector
BECS ESRI Connector prerequisites
BECS ESRI Connector requires:
BECS ESRI Connector Installation Procedure
Whole process will drive following steps:
