BECS Datum 360 - PIM360 Connector
About Datum360 - PIM360
The Datum360 company provides an intelligent way to manage Engineering Information and Asset Management data requirements. Datum360 customers include a diverse range of global giants from multiple industry sectors.
PIM360 - which is Datum360’s information management platform - is the most efficient and agile platform for ensuring consistency and quality of engineering and asset data.
BECS Datum360 - PIM360 Connector enables very easy and quick integration between Datum360 PIM360 and other systems. It has implemented the following set of functions:
BECS Datum360 - PIM360 Connector Documentation
How to install BECS Datum360 - PIM360 Connector
BECS Datum360 - PIM360 Connector Prerequisites
BECS Datum360 - PIM360 Connector requires:
BECS Server version 5.5 or higher
BECS Visual Architect version 5.5 or higher
BECS Datum360 - PIM360 Connector Installation Procedure
Whole process will drive following steps:
BECS Datum360 - PIM360 Connector Downloads
