Applies To | ||||
Product(s): |
eB Web/Director | |||
Version(s): |
15.4.x.x | |||
Environment: |
N/A | |||
Area: |
Login | |||
Subarea: |
Original Author: |
Nitin Bhui, Bentley Technical Support Group |
Problem:
Getting Error while logging in to the Director ‘The server process could not be started because the configured identity is incorrect. Check the username and password. (Exception from HRESULT: 0x8000401A)’
Error:
Unable to communicate with the Application Server on (servername). Please ensure that the server is accessible from this (servername) machine, that the correct version (15.4.1.325) of the Application Server is being referenced and that the Index Service is running.
Workaround:
This is happening because you must have changed the password for the eB account which is being used to start the service.
Where you can see the ‘Enterprise Informatics eB’ as shown below
