Product(s): | APM Implementation and Performance Management | ||
Version(s): | 7.x+ | ||
Environment: | N\A | ||
Area: | N/A | ||
Subarea: | N\A |
Asset Data loader is not working. We are importing asset records via excel template. System showing the import request is processed successfully but we are observing that the right assets with required data parameters are not loading in the system.
The Server Instance running the data loader service provider needed to be restarted, then it worked as expected.
APM Help - Administration Guide - Data Loading
Ref: 7000780542
Original Author: | Giselle Notte |
