Applies To | |
Product(s): | OpenPlant Modeler |
Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) |
Environment: | Windows 7/8.1/10 (64 bit) |
Area: | Component |
Subarea: | Graphics |
Original Author: | Rahul Kumar, Bentley Product Advantage Group |
Option to Delete/Replace the Flange Assembly in Open Plant Modeler
There are two ways to do this:
Option A: Whenever a flange/gasket/bolt is deleted within an assembly, it will be inserted again due to auto-fitting as per design in the current workflow in OpenPlant Modeler.
To delete the flange in such case you can disconnect the pipe through manipulator and drag the pipe to opposite direction. You will be able to delete the flange easily. See image for reference.
Option B: You may use quick replace option if you want to replace it with other flange. See image below for your reference.
communities.bentley.com/.../273478
