Applies To | |
Product(s): | OpenPlant Isometrics Manager |
Version(s): | 08.11.09.XXX(SS5) | 08.11.11.XXX (SS6) |
Environment: | Windows 7/8.1/10 (64 bit) |
Area: | OpenPlant Isometrics Manager for AutoPLANT |
Subarea: | Installation |
Original Author: | Abhijit Bute, Bentley Product Advantage Group |
During OpenPlant Isometrics Manager installation procedure user need to select the correct options. Following are the steps of installation for AutoPLANT Modeler - OpenPlant Isometrics Manager.
After installation of AutoPLANT Modeler, Run OpenPlant Isometrics Manager exe. See step by step procedure
Note - Check OFF OpenPlant ModelServer Mode option when installing it for AutoPLANT Modeler side.
Click on Finish and OpenPlant Isometrics Manager is ready to use along with AutoPLANT Modeler.
When a version of OpenPlant Isometrics Manager exists on the user machine and he wants to upgrade it to the latest version then he needs to follow the below mentioned steps.
communities.bentley.com/.../openplant-isometrics-manager-for-autoplant
