Applies To | ||
Product(s): | OpenPlant PID | |
Version(s): | 08.11.09.564 (SS5) | 08.11.11.XXX (SS6) | |
Environment: | Windows 7/8.1/10 (64 bit) | |
Area: | Errors, Logs, Messages, Crashes - OpenPlant PID | |
Subarea: | - | |
Original Author: | Swapnil Joshi, Bentley Product Advantage Group |
Project ID 'XXXX' not found in AT_PROJ.DB3
When the user tries to open a PID model he is prompted with this message. This issue is not faced when he is working in offline mode (i.e. without Plant Framework).
The steps mentioned in the wiki help us resolve the issue.
Open PID Project pcf file.
communities.bentley.com/.../database-plant-project
