How to Delete Ecxml Files, after certain Period
Product(s):OpenPlant Isometrics Manager
Version(s):08.11.12.226/08.11.14.xxx
Environment:Windows 7/8.1/10 (64 bit)
Area:Open/Save
Subarea:-
Original Author:Abhijit Bute, Bentley Product Advantage Group
How to delete Ecxml files after certain periods
When processing isometric, Isometric generation process creates Ecxml files.
Ecxml for generally use to analyze the cause of error arise while, processing isometric.Saturated such Ecxml files increase project size, which further effect on Isometric Generation process as we well Project Packaging process.
Following setting helps to delete Ecxml files after specific period.
  1. Go to Project Administrator.
  2. Select the project.
  3. Go to OpenPlant Isometrics>Settings
  4. Delete intermediate Ecxml files After 2 days or set as per requirement.
  5. In AutoPLANT Modeler version SS7 Delete intermediate Ecxml files option not available in Project Administrator interface.
            Below variable can be added in ‘AP2ECConverter.ini’ file located on project location,
            Ex: C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant
            STORE_TEMPDATA_IN_DAYS=1
communities.bentley.com/.../open-save---openplant-isometrics-manager-for-autoplant
Still a Problem?
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Comment and corrections?
