Applies To | Debugging/Logging |
Product(s): |
AutoPLANT Data Manager
Version(s): | V8i |
Environment: | N/A |
Area: | N/A |
Subarea: | N/A |
Original Author: | Brandon Moberg, Bentley Product Advantage Group |
Please follow the steps below to set up logging of the Data Manager application:
Download the required logging file at the location below:
communities.bentley.com/.../datamanager.aplogn.xml
- Place datamanager.aplogn.xml in the same folder as the datamanager.exe
(typically “C:\Program Files (x86)\Bentley\Plant V8i\Bin\datamanager.aplogn.xml”)
- Correct the log file path if necessary (currently it’s “c:\tmp\datamanager.log”), the folder should be accessible, so, for example, “Program Files” is NOT a good place. A good example to use would be “c:\tmp”. Make sure that this folder exists.
- Run Data manager and try and follow the steps to reproduce your error.
- Browse to and open the log file created in the c:\tmp folder.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
