Applies To | |
Product(s): | OpenPlant Isometrics Manager |
Version(s): | 08.11.09.XXX |
Environment: | Windows 7 (64 bit) |
Area: | Settings/Attributes |
Subarea: | - |
Original Author: | Abhijit Bute, Bentley Product Advantage Group |
By default, Output of Spectacle Blank Open and Spectacle Blank Close symbols are denotes with same symbol in isometric. If user want to show Different symbols following illustrative steps will help to achieve desired result.
Problem Description
When generate isometric for Spectacle Blank Open and Spectacle Blank Open symbol show following symbol.
Current Result:
Expected Result:
communities.bentley.com/.../settings-attributes---openplant-isometrics-manager-for-autoplant
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Comments or Corrections?
