Applies To | OpenPlant Isometric Manager Connect Edition |
Product(s): | OpenPlant Isometric Manager CE |
Version(s): | |
Environment: | Windows 8.1/10 (64-bit) |
Area: | Settings |
Subarea: | |
Original Author: | Harshavardhan K,Bentley Product Advantage Group |
Problem Description
Sometimes users come across below error which says out of 1 i-models, 1 model failed to load or were skipped while generating Isometric in-session and out-session. Also check the log file which shows the same error.
Reason
This is due to the regional settings are not set to English as default. We can use below steps to resolve this issue by changing the regional settings to English. The Error can be fixed by doing simple steps by the language preference in our Operating System Settings.
Steps to Resolve
communities.bentley.com/.../how-to-create-a-custom-symbols-in-openplant-isometric-manager
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
